thermal analysis
 what are all the important parameters should know before starting thermal analysis?
if anyone have thermal analysis tutorial related to PCB analysis please share?
regards,
shreeharsha
Re: thermal analysis
Hello!,
Take a look to this TUTORIAL in the IBERISA WEB Support page of the heat transfer analysis of a PCB using FEMAP with NX NASTRAN:
http://www.iberisa.com/soporte/femap/termico/Heat_Transfer_from_Chip_to_PCB.htm
Best regards,
Blas.
WEB: http://www.iberisa.com
Hey, I just wanted to drop by and give a huge THANK YOU!
I've been struggling with the heat transfer analysis of a PDB for a while now but the results didn't measure up with any of my actual experiments 8I've been using tools by linseis which are usually crazy accurate, so I was wondering why my simulation was so different to my actual results). After reading that tutorial, I got a much better grasp of PCB. So thanks a ton.
