thermal flow simulation
hi,
i am trying to solve thermal flow analysis of electronic enclosure. i am getting error when i solve.
please help me why this error is coming and what is remedy for this error?
i have attached both model and error image.
thanks,
regards,
shreeharsha
Re: thermal flow simulation
Dear shreeharsha,
Uff, you have many errorrs here of "concept", better practice first with FEMAP/TMG FLOW tutorials to learn how to define CFD problems properly, this is basic, OK?. For instance, the AIR material properties are defined as ISOTROPIC, not as FLUID, then the error. Regarding geometry, you need to use command GEOMETRY > SOLID > EMBED to embed the CHIP & PCB in the electronics box, etc...
Best regards,
Blas.
WEB: http://www.iberisa.com
Thank you
