Geometry Optimization to perform quick what-if design studies
Community Manager
Geometry Optimization allows you to perform quick what-if design studies. This NX CAE Quick Tip shows how to optimize your FE simulation by varying geometric parameters. Geometry optimization allows you to iterate your solutions and easily to geometry-based solutions to determine the best design which meet specific design requirements.
(view in My Videos)
Ganesh
Simcenter 3D Community Manager
Simulation and Test Solutions
Comments
Theorist
Theorist
My optimization failed to update the geometry. How can i find the iteration parameters nx used and failed to update the geometry? In excel sheet i can see the last iteration parameters which was successfully analyzed. But i cannot see the next iteration parameters that nx used to update the geometry and couldn't.
Community Manager
@MarkLamping do you think you could help answer @TUBITAK's question?
Contributors
