NXCAE13: American Axle & Manufacturing
Community Admin Community Admin
Community Admin
NX and LMS Test.Lab Integration at American Axle & Manufacturing
The following presentation was given at the 2013 NX CAE Symposium by Alexandra Sandstrom.
Alexander Sandstrom graduated with a bachelors in mechanical engineering from the University of North Carolina at Charlotte in 1999. Started in the Chrysler Technical Center in the NVH lab in early 2000 until the middle of 2001 when he joined LMS. At LMS he was responsible for project management in the Engineering Services Department as well as business development activities and gained extensive experience using LMS Test.Lab and Virtual.Lab. In the fall of 2010 Alexander started at AAM as Sr. NVH Project Engineer and was responsible for the NVH performance of the newly productionized Eco-Trac system. He since moved to the NVH CAE team and is involved in the upfront prediction of axle gear mesh excitation and vehicle integration issues.
The presentation is also available for download at the end of this article.
If you find my post helpful, and it answers your question, please mark it as an "Accepted Solution"
Contributors
