cancel
XY Plotting using the Femap Charting Pane
The attached tutorial on the use of the new Charting Pane is from the Femap 101 for Femap v11 class.  The PDF file included in the Exercises folder in the .zip file.  You can arrange the PDF file with your Femap session as shown below.
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
