BCTPARM CARD
Hello Community,
I'm trying to calculate a nomal Bolt Pre Load with 1D Elements.
After calculation, there's a displacement which is not possible.
Now someone told me, that i can fix this Problem with the REDFAC = 1 Parameter in the Nastran File.
But i don't know exactly where i can write i down.
Thank your for your help
Re: BCTPARM CARD
The First Part of the Nastran File. Here must the
BCTPARM
Redfac 1
be set.
$* NX v10.0.2.6 TRANSLATOR
$* FOR NX NASTRAN VERSION 10.2
$* FEM FILE: H:\Siemens\FEM\Ruks\Schrauben\ANALYSIS__SCHRAUBEN__2016_11_02_catproduct_assyfem1.afm
$* SIM FILE: H:\Siemens\FEM\Ruks\Schrauben\ANALYSIS__SCHRAUBEN__2016_11_02_catproduct_assyfem1_sim1.sim
$* ANALYSIS TYPE: Structural
$* SOLUTION NAME: Solution 1
$* SOLUTION TYPE: SOL 101 Linear Statics - Global Constraints
$* SOLVER INPUT FILE: analysis__schrauben__2016_11_02_catproduct_assyfem1_sim1-solution_1.dat
$* CREATION DATE: 21-Nov-2016
$* CREATION TIME: 12:54:05
$* HOSTNAME: PC-2517
$* NASTRAN LICENSE: Desktop Bundle
$* UNITS: mm (milli-newton)
$* ... LENGTH : mm
$* ... TIME : sec
$* ... MASS : kilogram (kg)
$* ... TEMPERATURE : deg Celsius
$* ... FORCE : milli-newton
$* ... THERMAL ENERGY : mN-mm (micro-joule)
$* IMPORTANT NOTE:
$* This banner was generated by NX and altering this information
$* may compromise the NX post processing of results.
$* FILE MANAGEMENT
$* EXECUTIVE CONTROL
ID,NASTRAN,analysis__schrauben__2016_11_02_catproduct_assyfem1_sim1-solution_1
SOL 101
CEND
$* CASE CONTROL
ECHO = NONE
SPC = 1
BCSET = 100
OUTPUT
DISPLACEMENT(PLOT,REAL) = ALL
SPCFORCES(PLOT,REAL) = ALL
STRESS(PLOT,REAL,VONMISES,CENTER) = ALL
$* NX Step: Subcase - Static Loads 1
SUBCASE 1
LABEL = Subcase - Static Loads 1
LOAD = 5
$* BULK DATA
BEGIN BULK
$* SOLUTION CARDS
BCTADD 100 101 102 103
$* NX Load and Constraint: Face Contact(2)
BCTSET 101 3 40.300000 0.00001.000000
$* NX Load and Constraint: Face Contact(3)
BCTSET 102 5 60.300000 0.00001.000000
$* NX Load and Constraint: Face Contact(1)
BCTSET 103 1 20.300000 0.00001.000000
$* PARAM CARDS
PARAM AUTOMPC YES
PARAM K6ROT100.0000
PARAM OIBULK YES
PARAM OMACHPR YES
PARAM POST -2
PARAM POSTEXT YES
PARAM UNITSYS MN-MM
$* GRID CARDS
Re: BCTPARM CARD
If you want this to apply to all pairs, the format would be:
BCTPARM, 100, REDFAC, 1.0
If you wanted it to apply to an individual contact pair, the format would be:
BCTPARM, 101, REDFAC, 1.0
Note that BCTPARM is a bulk data card. It can be anywhere in bulk data. I'd suggest putting it near the BCTADD/BCTSET cards.
