cancel
Cable problem
Innovator
Innovator
Hello Experts,
I want to know how to solve this cable problem using NX AdvSim 7.5 & NX NASTRAN, this task of cable problems are critical for some prospects, then I should like to know how to do it in NX7.5 using both NX NASTRAN basic nonlinear model (NLSTATIC SOL106) and also Advanced Nonlinear module (SOL601), thanks!.
In this example a suspended cable is subjected to uniform self-weight and concentrated loads.
The geometry, properties, loading, and theoretical results can be found in Section 4.6.2, Figure 4.16 and Table 4.1 of Tibert, 1999.
Best regards,
Blas.
Re: Cable problem
I've asked the same about a rope/chain. See here:
http://bbsnotes.ugs.com/vbulletin/showthread.php?t=42988&highlight=rope
We also made some detailed experiments about the modeling of a rope in 101 and 106. If our student is finished with writing down I will post it.
Regards, Maik
NX 7.5.2, NX-Nastran 7.1
Re: Cable problem
Innovator
Innovator
Hello!,
Not any answer arrived??. The problem is simply posed, then I would love to be able to have a solution to this nonlinear problem, thanks in advanced!.
Best regards,
Blas.
