Can Modal Response Functions be obtained when running a SOL112?
I make use of the Modal Response Functions that I can compute when executing a Response Dynamics Solution Process (which uses SOL103RS). I would like to evaluate the benefits of using SOL112 (Modal Transient Response Analysis) but have not been able to find any way to compute Modal Response Functions.
Does anyone know if it is possible to compute Modal Response Functions when running a SOL112?
Re: Can Modal Response Functions be obtained when running a SOL112?
Answer from GTAC:
You can use output requests sdisplacement, svelocity, and sacceleration to get the modal response functions for SOL112. Use SORT1 format for these if you want to import them as AFU functions in NX.
