Contact in NX8
I am student and have a propably short question (using NX8).
I want to create a simulation of a falling sphere on a thin plate. I use SOL 601, 129, but the "results"-button disappears after solving.
I tried to create a Surface-to-Surface-Contact, the plate as the bottom-region and the sphere as the top-region. But no results after solving...
I hope you can help me. Thank you very much!
Best regards from Germany
Robin
Re: Contact in NX8
Hi Robin,
Here is the modified files. A lot of parameters changed.
The main reason why you are not getting your result is because you did not use Strategy Parameter at all. ATS (automatic time stepping) setting is required whenever Sol601 is used.
Tuw
Re: Contact in NX8
Hello Tuw,
thank you very much for your reply.
I tried to rebuild it and tried to figure out, what your changes have been. I thought I found all changed paramters, but my solution stops exactly before contact. Do you have a final advice?
Many regards,
Robin
Re: Contact in NX8
The ground plane need to the 2D mesh.
Tuw
Re: Contact in NX8
Thank you! It is working.
Many, many thanks!
Best regards Smiley Happy
Robin
