Error in parallel processing, Solution stops in between iterations with error!
I have a project in which the boundary condition changes with time and calculation uses  an 8 processor machine, This is the error I typically encounter over a period of time in the solution monitor:
| Thermal Enclosure - Step 4518 |
| CSOLVER | Minimum | Location | Maximum | Location | Average Convg|
| T-Solid | 8.26E+01 | 261518| 8.29E+01 | 253784| 8.27E+01 OK |
| Coupled thermal convergence | Heat balance
| Criteria | Rate | |Change| | Msg | To fluid: 5.148e-003
+-----------------+--------+--------------+-------+ (5.148e-003)
| Heat Imbalance | 1.07 | 2.461e-006 | OK | To solid: 5.134e-003
| Max delta T | 1.00 | 1.526e-005 | OK | (5.134e-003)
unable to read the cmd header on the pmi context, Error = -1
Error posting readv, An existing connection was forcibly closed by the remote host.(10054)
op_read error on parent context: Error = -1
unable to read the cmd header on the parent context, Error = -1
connection to my parent broken, aborting.
state machine failed.
op_read error on left context: Error = -1
unable to read the cmd header on the left context, Error = -1
Someone plz help me overcome this!
