Error when applying moment load
Hello everyone!
I am trying to apply a moment force to a spline set. Moments added onto the end.Moments added onto the end.
The current error I get is:  "Moment(1)" has an incompatible mesh when applying moment to splines
How can I correctly apply the torque load to my splines(Torques only work with cylinders)?
Thanks!
Re: Error when applying moment load
Another solution may be :
- Create manually an extra node on the axis of rotation,
- Connect it to the nodes of your splines (to do it, use 1D Connection on the fem toolbar, choose a RBE2 connection element),
- Apply the moment load only on this extra node,
- Solve...
