Experimental Modal Analysis and Model Updating - NX 10
Hello everyone,
I'm currently working on my master thesis entitled "Experimental Modal Analysis of a Formula Student Car Chassis" in which i aim to evaluate experimentally the natural frequencies and mode shapes and compare those result with the numeric ones. I also pretend to include a chapter on Model Updating of the Finite Element Model based on experimental results.
I am using Siemens NX 10 to perform the modal analysis and the correlation with the experimental results.
I already tried that with a much simpler geometry, a GFRP plate and i obtained good results.
The problem now is that i can't go further to the model updating with the plate. Does anybody has any documentation on that Siemens NX 10 add-in or can help me with some suggestions?
Miguel
Re: Experimental Modal Analysis and Model Updating - NX 10
Siemens Genius Siemens Genius
Siemens Genius
Siemens Genius
That's exactly what i was trying to find.
Thank you very much.
Miguel
