Filled Contours on Beam Elements
N/A
Is it possible to display contour plots of stresses on Beam elements?
I can display criteria values, but not contour.
Re: Filled Contours on Beam Elements
N/A
Sorry I'm new to this - forgot to mention software version.
I'm using Femap 9.2 with NX Nastran 4.1
N/A
Barrie,
Femap users could best answer this question and I don't know if many of them use
this board. I will try to get an answer from someone for you.
N/A
Thanks for the reply Mark.
I hadn't looked at the available newsgroups for a while and didn't realise
there was a Femap bulletin board.
I'll try my luck over there.
