Folder Path for Universal File (Envelop Builder)
Hello all,
i am using envelop/reduction/combination builders for post processing the results.
I would like to know, in a journal for a universal file, how can I refer to the folder path where the solution results are stored ?
Currently I am changing the path manually but this is not a good solution for standerdisation.
thanks in advance for your help and suggestion
Re: Folder Path for Universal File (Envelop Builder)
You can use NXOpen.CAE.SimSolution.GetResultFile(). This will return the path and the filename of the results file.
