Geometric Non Linearity..........
Hi, Please tell me which solver should I used  in NX 9 to give time steps for non linear analysis. I have to  find the displacement  at different time steps. Also please tell me how to give time steps in  that solver.....
Re: Geometric Non Linearity..........
SOL 106 can increment loads on a subcase by subcase basis. You can change the load sets, or the load scaling on a LOAD bulk data card to increment loads between subcases.
SOL 601,106 uses pseudo-time. You can define "time dependent" load scaling and a solution time stepping scheme. Note that time is only used for load incrementing - there are no velocity or inertia effects due to the time dependency.
