Graphs are missing!
usually after the start of my simulation a window appears and it looks like this:
My newest simulation is complete self created and i usually use existing templates.
So now i started the new simulation and used the same settings. (i think)
But this time the 2 right tabs are missing, so i don't see the graphs.
Is there any setting where i can turn on those 2 tabs?
Or does somebody know why they are not appearing?
I use solver SOL 601,106 non linear static.
Sorry for the german version but i think you will get my point.
best regards
marius
Re: Graphs are missing!
Do you mean that the analysis is running but without these two graphs or there is no launching at all?
Usually when you dont get the graphs, it is because you use a version of nastran different from the NX version you use (NX 11 with NX Nastran 9.0 for example).
Naguib
