How to display forces and constraints in Post View?
Hi everyone,
how do I display forces and/or constraints (as in the arrows and lines you can see in the sim file before loading any results) in post view when I, for example, look at a contour plot of Von-Mises stress?
Surely this must be possible? But I haven't found anything in the "Edit Post View" menu...
Best regards
CC-
Re: How to display forces and constraints in Post View?
See this article in Solution Center:
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&p=1&q=post+processing+l...
Once visibility is set for all layers, you can turn model entities on and off as normal (using the visibility toggles on the Navigator, using Show/Hide, etc.)
