cancel
How to simulate ropes or chains
I can't find any possibility in NX6 to create elements or manipulate for simulating ropes or chains. Does anybody know how I can do that in NX6 with NX-Nastran.
Thanks, Maik
NX 7.5.2, NX-Nastran 7.1
Re: How to simulate ropes or chains
Siemens Builder Siemens Builder
Siemens Builder
In the Advanced nonlinear solutions, you could use rod elements with a nonlinear elastic material (MATS1 with TYPE=NLELAST).
In SOL 106, you could use PBUSHT type KN.
In SOL 101, you could use gap elements set up as 'hooks'. Be sure to toggle on the 'Treat CGAP as Linear Contact Elements' toggle on the edit solution form in NX.
Jim Bernard
Advanced Applications Engineer
Siemens PLM Software
2000 Eastman Dr., Milford, OH 45150-2712
www.siemens.com/plm
Hello Jim,
thanks for the reply and help. I will give it a try.
Thanks, Maik
I tried to use the CGAP in SOL101 but I'm not able to get the behavior of a rope. I played hit the contact stiffness, etc. but no success. :confused:
@Jim: Is it possible to give me another tip.
Thanks, Maik
N/A
Gap elements in sol 101 behave just like linear springs. You need to use sol 106 for gaps to have the bilinear behavior.
You can also use the nonlinear elastic material trick for a rod in sol 106.
Siemens Builder
Joe,
This is true in other Nastran versions. However, in NX Nastran, if you add a BCSET card to your case control (and leave system cell 412/OLDGAPS set to it's default of 0) in SOL 101, the CGAP elements will be treated as linear contact elements.
The gap stiffness comes from KA and KT on PGAP by default. System cell 464 can be set to have gap stiffness determined from the linear contact penalty factors.
Jim Bernard
www.siemens.com/plm
Siemens Builder
Thanks, Maik
Here's an example NX database with NX Nastran input decks and output files. There is a SOL 106 and SOL 101 version of the same model using CGAPS. Results are identical. Axial force in the cable/rope is zero in the compression subcase.
Jim Bernard
www.siemens.com/plm
Hello Jim,
thanks for the input decks. My falt was an wrong model(see 1 sketch in PDF). I thought its enough to set the open/close stiffness so that the stiffness for open contact has an high value and for closed stiffness the other way around.
Thanks all for helping, Maik
