Hydrostatic pressure in NX6
N/A
i want to apply a hydrostatic pressure in a tank volume meshed in shell elements.
i did pick the mesh on the volum of the tank and applied the hydrosttaic pressure
from UGI, but i am bit confused about the vector direction.
does the vector direction control the depth of the tank? does it need to be default
(-Z)?
when i change the vector from -Z into -X the value of the pressure per unit area
change in PLOAD4 card.
Many thanks,
Re: Hydrostatic pressure in NX6
N/A
"engrequest" wrote:
>Hi,
>default
>(-Z)?
>area
>Many thanks,
From the NX Help for the Liquid Surface block of the Hydrostatic Pressure dialog
box:
Specify Vector: Defines the direction downward from
the surface of the liquid. The default
direction is –Z.
Specify Point: Specifies the location of the surface
of the liquid. The default location
is (0,0,0).
In other words, you're simply defining a plane representing the fluid surface by
specifying a point and normal vector. The vector points "down" into the fluid.
N/A
Thanks Jim,
i am just wondering whether the hydrostatic pressure is the right option to model
a fluid (water) pressure inside a reservoir volume.
i need to apply a pressure into the shell elements on the reservoir surfaces.
Many Thanks,
"Jim Bernard" wrote:
>"engrequest" wrote:
>>Hi,
>elements.
>pressure
>be
>>default
>>(-Z)?
>>area
>>Many thanks,
>dialog
>box:
> direction is –Z.
> is (0,0,0).
>by
N/A
wrote:
>Thanks Jim,
>model
>Many Thanks,
>>"engrequest" wrote:
>>>Hi,
>>elements.
>>pressure
>>be
>>>default
>>>(-Z)?
>>>area
>>>Many thanks,
>>dialog
>>box:
>> direction is –Z.
>> is (0,0,0).
>>by
If you want the pressure to vary with the fluid depth, then hydrostatic pressure
is what you need.
Jim
