MATSMA Errors
I keep getting this error when doing non-linear with 601. I am trying to model Nitinol. If I use a normal material one I make myself, it does't give any problems. However, I get problems whenever I create a Shape Memory Alloy. The materials properties for it I get from a text book.
NASTRAN Msg: ***WARNING: THE FOLLOWING LIST SHOWS UNSUPPORTED FIELDS FOR CERTAIN
BULK DATA
ENTRIES PROCESSED IN THIS INPUT FILE. YOUR MODEL MAY BE
AFFECTED
NASTRAN Msg: *** ERROR NO. A1396 ***
NASTRAN Msg: *** FATAL ERROR: SOL 601 DID NOT FINISH SUCCESSFULLY.
*** ADVANCED NONLINEAR EXIT CODE 0 ***
NASTRAN Msg: ^^^ USER FATAL MESSAGE
^^^ ERROR IN ADVANCED NONLINEAR MODULE 0
Total messages: 1 WARNING and 3 FATALS
I can't find error number A1396 anywhere in the documentation or the nastran error list. Can someone help?
Re: MATSMA Errors
Just needed to define the temperature
