Do you mean
Reply
Manipulating Nastran output results
Is there any way to make simple calculations on restults? ie. multiply
the Von Mises stress output by a factor, or take the log of it, and
display the results in contour plot?
Thanks in advance,
Tamas
Re: Manipulating Nastran output results
Dear Tamas,
I understand you runs NX6AdvSim. OK, when you solve any linear static analysis where you have two or more "subcases" if you click with RMB on RESULTS you will see the command "Combined Loadcases" where you can create any secondary load case using factors based in previous primary subcase results. This is a postprocessing action, if you do double-click on results, your screen will switch to Postprocessing Navigator and you will be able to plot contour results of all primary & secondary load cases as normally -- is this what you were looking for?.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
Edificio Ercilla
Rodríguez Arias 23, 3º - Dpto. 19
48011 BILBAO (SPAIN)
Tel. (+34) 94 410 65 50
Fax. (+34) 94 470 26 34
E-mail: info@iberisa.com
WEB: http://www.iberisa.com
"Tamas" escribió en el mensaje de noticias news:4b0fd35b@bbsnotes.ugs.com...
> Hello,
> Thanks in advance,
> Tamas
You can multiply the results by a factor by right-clicking on Post-View,
choose "Set Result".
Choose a scaling factor, the default is 1.
Thanks I will give it a try
Tamas
