Modeling a Bolted Connection
I found a link to a NX Nastran Forum on this subject but it goes to an unfound page.  Here is the text under the link:
"Modeling a Bolted Joint With NX Nastran" In order to model a bolted interface, both preload and surface contact must be used. Some best practices for solving ...
Is there a way to get to this document or are there other documents available to help on this subject?
Re: Modeling a Bolted Connection
I believe I have contacted the original requester and set the video's directly to him. Typically videos over 2 years old are obsolite and not available however this person was using very old software.
