NX Nastran 11 Multiphysics (401)
I would like to ask you if is possible set as "End Time" of the analysis (in NX Nastran 11 - Multiphysics - Multi-step Nonlinear) some value from results of the analysis. More precisely, I would like end the analysis when Laminate Failure Index (V-3) reach =1. Because these results (Solid Laminate Failure Index) show in every step only values of the "End step" (and I have to find the time of a final step value for FI = 1).
End Time:
FI
S.
Re: NX Nastran 11 Multiphysics (401)
This is not possible with out of the box functionality.
You could possibly do it via a DMAP alter
Ok, I try it (DMAP).
Thank you
S.
