cancel
NX Nastran 9.0 Installation Error
Builder
Builder
I have just downloaded the Windows version of NX9.0 (after several failed attempts).
I have unpacked the file and I have tried to install it on one of my colleagues workstation. After the initial information entering, the routine gets into the copying of files and aboy 50-60% of the way through, I hit the following error:
CreateFile failed.C:\Program
Files\Siemens\NXNastran\nxn9\64bit\conf\nast9.rcf,
I hit the "Ok" button and the intallation routine exits.
Has anyone hit this problem and found a solution?
Thanks!
Re: NX Nastran 9.0 Installation Error
Builder
Builder
I found out my error.
When installing the software, I needed to start the installer as "Run as Administrator". From there, no problem.
