NX flow benchmark
N/A
Any one knows where I can find independent NX flow and advanced flow benchmarks ?
Re: NX flow benchmark
N/A
Dear Benjamin,
You have plenty of CFD validation examples in the literature and in the Internet, for instance:
http://www.grc.nasa.gov/WWW/wind/valid/tutorial/links.html
In CFD-Online you have interesting material with validation cases:
http://www.cfd-online.com/Links/refs.html
Here you are a list of references with CFD verification & validation examples:
a.. 1 Schlichting, H., Boundary Layer Theory. 7th ed., McGraw -Hill, New York, 1979.
b.. 2 Idelchik, I.E., Handbook of Hydraulic Resistance. 2nd ed., Hemisphere, New York,1986.
c.. 3 Panton, R.L., Incompressible Flow. 2nd ed., John Wiley & Sons, Inc., 1996.
d.. 4 White, F.M., Fluid Mechanics. 3rd ed., McGraw-Hill, New York, 1994.
e.. 5 Artonkin, V.G., Petrov, K.P., Investigations of aerodynamic characteristics of segmental conic bodies. TsAGI Proceedings, No. 1361, Moscow, 1971 (in Russian).
f.. 6 Holman, J.P., Heat Transfer. 8th ed., McGraw-Hill, New York, 1997.
g.. 7 Henderson, C.B. Drag Coefficients of Spheres in Continuum and Rarefied Flows. AIAA Journal, v.14, No.6, 1976.
h.. 8 Humphrey, J.A.C., Taylor, A.M.K., and Whitelaw, J.H., Laminar Flow in a Square Duct of Strong Curvature. J. Fluid Mech., v.83, part 3, pp.509-527, 1977.
i.. 9 Van Dyke, Milton, An Album of Fluid Motion. The Parabolic press, Stanford, California, 1982.
j.. 10 Davis, G. De Vahl: Natural Convection of Air in a Square Cavity: a Bench Mark Numerical Solution. Int. J. for Num. Meth. in Fluids, v.3, p.p. 249-264 (1983).
k.. 11 Davis, G. De Vahl, and Jones, I.P.: Natural Convection in a Square Cavity: a Comparison Exercise. Int. J. for Num. Meth. in Fluids, v.3, p.p. 227-248 (1983).
l.. 12 Emery, A., and Chu, T.Y.: Heat Transfer across Vertical Layers. J. Heat Transfer, v. 87, p. 110 (1965).
m.. 13 Denham, M.K., and Patrick, M.A.: Laminar Flow over a Downstream-Facing Step in a Two-Dimensional Flow Channel. Trans. Instn. Chem. Engrs., v.52, p.p. 361-367 (1974).
n.. 14 Yanshin, B.I.: Hydrodynamic Characteristics of Pipeline Valves and Elements. Convergent Sections, Divergent Sections, and Valves. "Mashinostroenie", Moscow, 1965.
o.. 15 Jyotsna, R., and Vanka, S.P.: Multigrid Calculation of Steady, Viscous Flow in a Triangular Cavity. J. Comput. Phys., v.122, No.1, p.p. 107-117 (1995).
p.. 16 Darr, J.H., and Vanka, S.P.: Separated Flow in a Driven Trapezoidal Cavity. J. Phys. Fluids A, v.3, No.3, p.p. 385-392 (1991).
q.. 17 Michelsen, J. A., Modeling of Laminar Incompressible Rotating Fluid Flow, AFM 86-05, Ph.D. Dissertation, Department of Fluid Mechanics, Technical University of Denmark, 1986.
r.. 18 Sorensen, J.N., and Ta Phuoc Loc: Higher-Order Axisymmetric Navier-Stokes Code: Description and Evaluation of Boundary Conditions. Int. J. Numerical Methods in Fluids, v.9, p.p. 517-1537 (1989).
s.. 19 Enchao Yu, Yogendra Joshi: Heat Transfer Enhancement from Enclosed Discrete Components Using Pin-Fin Heat Sinks. Int. J. of Heat and Mass Transfer, v.45, p.p. 4957-4966 (2002).
t.. 20 Kuchling, H., Physik, VEB FachbuchVerlag, Leipzig, 1980.
u.. 21 Balakin, V., Churbanov, A., Gavriliouk, V., Makarov, M., and Pavlov, A.: Verification and Validation of EFD.Lab Code for Predicting Heat and Fluid Flow, In: CD-ROM Proc. Int. Symp. on Advances in Computational Heat Transfer "CHT-04", April 19-24, 2004, Norway, 21 p.
v.. 22 Visser, F.C., Brouwers, J.J.H., Jonker, J.B.: Fluid flow in a rotating low-specific-speed centrifugal impeller passage. J. Fluid Dynamics Research, 24, pp. 275-292 (1999).
w.. 23 Wesley, H. B., and Spyros, A. K.: Experimental and computational investigation of sheet cavitation on a hydrofoil. Presented at the 2nd Joint ASME/JSME Fluid Engineering Conference & ASME/EALA 6th International Conference on Laser Anemometry. The Westin Resort, Hilton Head Island, SC, USA August 13 - 18, 1995.
x.. 24 Yershova, L., Volodin, V., Gromov, T., Kondratiev, D., Gromov, G., Lamartinie, S., Bibring, J-P., and Soufflot, A.: Thermoelectric Cooling for Low Temperature Space Environment. Proceedings of 7th European Workshop on Thermoelectrics, Pamplona, Spain, 2002.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
Edificio Ercilla
Rodríguez Arias 23, 3º - Dpto. 19
48011 BILBAO (SPAIN)
Tel. (+34) 94 410 65 50
Fax. (+34) 94 470 26 34
E-mail: info@iberisa.com
WEB: http://www.iberisa.com
"benjamin muyl" escribió en el mensaje de noticias news:49b5662a$1@bbsnotes.ugs.com...
> Thanks
