NX material library DBC_init_db failed
I receive strange errors when I click on "Manage Materials" within NX 10 - Advanced Simulation only for the first time after I have started NX. The error message is "NX material library DBC_init_db failed". Checking the syslog file doesn't help me (see attachment). I'm at a loss ;-)
Do you have any hint? Where is the error (probably mine, of course)?
Thank you in advance, many greetings
muppets
Re: NX material library DBC_init_db failed
Sorry, I don't want to get on anybody's nerves, but the problem preys pretty on my mind ...
Does really nobody know this problem? I've attached the message boxes showing the error messages.
Thank you, greetings
muppets
