Do you mean
Reply
NX mesh for Moldflow
is that possilbe for export NX mesh to Moldflow for downstream operation insdie MF ?
The reason is that we need lot of time to create 'good mesh' inside Moldflow,but NX mesh generator is quite powerful.
Thx,
Joe.
Re: NX mesh for Moldflow
Dear Joe,
I do not run Moldflow but I am sure that will support the import of FE mesh from NASTRAN bulk data (other molding softwares like MoldEX3D do it perfectly). If you run NX AdvSim you will be able to mesh your part and export the nx nastran *.DAT file to import in Moldflow.
Best regards,
Blas.
