No Simulation using Strength Wizard ??
N/A
Hi
We have Problem that we can't output the analizing Result / Animation
within Strength Wizzard. ( See Picture ) Can anybody help.
Roland
Re: No Simulation using Strength Wizard ??
N/A
"Roland Hofmann" wrote:
>Hi
>regards
>Roland
The image you attached has such poor resolution that all of the text is unreadable.
N/A
Hi Jim
Here is another one.
>>Hi
>>regards
>>Roland
N/A
Roland,
The Nastran solution likely failed which is the reason you do not have results.
Are you sure that you have NX Nastran installed correctly. It is done as a separate
install from NX. I have attached the readme file with instructions for installing
NXN 5 version.
If you think it is installed correctly, the other possibility is that there is some
type of licensing problem. If you want to send your license file, and a Flexlm log
file of your session, we can see what might be happening. It would also be good
to get your Nastran files with appendages of .log and .f06
Mark
>Hi Jim
>>>Hi
>>>regards
>>>Roland
