Option to Mesh "Industrial Wire Mesh"
I am looking for an option to mesh "Industrial Wire Mesh" in NX "Pre/Post" (NX Nastran) while i am using NX 11
Thank you for you help. Attached is the exmaple of industrial mesh that I would be using.
1 REPLY
Re: Option to Mesh "Industrial Wire Mesh"
Hello!,
I suggest to create a GLOBAL finite element model meshing with 1-D beam CBEAM elements, this way you will have a result in the form of nodal displacements & element stresses. Next if you need a more detailed answer, you can isolate the location and mesh with 3-D Solid elements and use rigid RBE2 "spider-like" elements to pass from BEAM to SOLID in the interface areas.
Best regards,
Blas.
WEB: http://www.iberisa.com
