Please provide solution to NX Nasteran ERROR "exception caught by Nastran model setup check"
Solution Model Setup Check Error Summary
 Solver is NX NASTRAN
 Environment: NX NASTRAN - Structural
 Solution is SESTATIC 101 - Single Constraint
Mesh-Based Errors Summary
Information listing created by :  Admin
Date                           :  7/26/2015 4:53:12 PM
Current work part              :  C:\Documents and Settings\Admin\Desktop\FEA\Example_3\sim1.sim
Node name                      :  home-a51f7ae7ea
*** 16:53:06 ***
Starting Nastran Exporter
*** 16:53:06 ***
Writing file C:\Documents and
Settings\Admin\Desktop\FEA\Example_3\sim1-solution_1.dat
*** 16:53:07 ***
Writing Nastran System section
*** 16:53:07 ***
Writing File Management section
*** 16:53:07 ***
Writing Executive Control section
*** 16:53:07 ***
Writing Case Control section
*** 16:53:07 ***
Writing Bulk Data section
*** 16:53:08 ***
Writing Nodes
*** 16:53:14 ***
ERROR : Invalid node id top retrieve coordinates : 92729
Export terminated because of error
Date                           :  7/26/2015 4:54:54 PM
Re: Please provide solution to NX Nasteran ERROR "exception caught by Nastran model setup check
Hello!,
Something is wrong with your mesh, then the message:
Locate you node 92729 and see what type of mesh is associated with this node and revise the procedure followed to create that mesh, without the model in hand little more we can say ..
Best regards,
Blas.
WEB: http://www.iberisa.com
