Do you mean
Reply
Simulation with a deformed part (sensitivity and tolerance analysis)
The task is the following:
- I have to take an original and ideal part
- This part then should be deformed (implement a bending) according to allowed tolerances
- With that part I have to do a contact analysis
Does anyone has an idea how I could get a deformed part (geometry) or deformed "mesh" from an ideal part?
thank you.
Re: Simulation with a deformed part (sensitivity and tolerance analysis)
This is a Solution 601/701 type of simulation. You will need the proper license to run these as they are adapted from Adina and it's extra money.
