cancel
Temp load stay inactive
This is a small 2D axisymmetric structural model, SOL106, CQUADX4 mesh, that has been run okay with mechanical only loading. I created a temperature load which maps thermal results from a separate thermal model via cartesian coordinate location from a datafile. All this looks okay based on my experience doing this in the past with ansys as the solver.
Problem:  In the load container, the temp load is Inactive. In Sim Navigator I've tried right clicking to make it active, double clicking on it, and also tried dragging it to active subcase loads folder.  When highlighted it is checked-on in load container but red circle is empty and it remains "Inactive". Any idea what is wrong? Any help would be greatly appreciated.
