Thermal transient analysis
Thermal transient analysis with Material Temperature dependent properties.
Is it possible ?
I tried and I got incorrect results (temperatures remain constant at the IC ones)
Franco
Re: Thermal transient analysis
Hi
I attach the Sol159 nastran input decks of my test models
SOL159_MAT4_ONLY.dat (the results are OK as I expect)
SOL159_MAT4_MATT4_TABLE.dat (the results are not OK, why ?)
Thank you
