USER WARNING MESSAGE 1152
N/A
I have problems with error below.
Can anyone help me?
Information listing created by : server_eds
Date : 17/02/2009 16.28.54
Current work part : D:\Appoggio Calcoli\simulazioni
nx6\optimization_sim1.sim
Node name : eds8
NASTRAN Msg: *** USER WARNING MESSAGE 1152 (XCLNUP)
SOME DBSETS IN THIS DATA BASE WERE NOT INITIALIZED
COMPLETELY.
Total messages: 1 WARNING and 0 FATALS
Re: USER WARNING MESSAGE 1152
N/A
I think the most likely cause is a failure of the system to create the scratch files
prior to the start of the analysis.
Check for write access, and ensure the discs are not full.
>Can anyone help me?
>Node name : eds8
>COMPLETELY.
N/A
I checked this but all appear configured correctly.
"Carlton Matthew" ha scritto nel messaggio
news:499c2c0b$1@bbsnotes.ugs.com...
> Hi,
> scratch files
>>Can anyone help me?
>>Node name : eds8
>>COMPLETELY.
N/A
Hi Fabio,
Try to delete or move all old files from the related directories (the directory
you are working in, and the scratch directory).
Hope this helps regards
Francesco
>> Hi,
>> scratch files
>>>Can anyone help me?
>>>Node name : eds8
>>>COMPLETELY.
I know this is an old thread, but this was one of the first places i looked.
I tried the steps posted here and nothing worked for me. There seems to be an issue with Nastran 6 and long names on files.
Try following for workaround:
- Either change name on the file you try to perform simulation on and make it short.
- Or if you run Design Simulation, try running Advanced instead
- Try a newer version of NX Nastran.
This worked for me.
