Unknown Error Occurred when attempting to show Test Model - Modal Correlation
I'm trying to do a correlation test between my numerical modal (FEM) and experimental one.
The experimental model geometry file has 76 nodes and 196 connections.
I don't know why but when i click to show the test model, in order to do the alignment with the numerical one, a window appear saying " Unknown Error Occured ".
But, then i tried to load another test model, a plate with 9 nodes and 17 connections and everything went ok. I was able to see the model, sensors, do the alignment, everything.
Both geometry and mode file were created the same way, with the same matlab program. I already checked them in a visualisation program and everything was ok.
There's any model size limit to do the correlation?
2 images attached to help understanding the problem.
Thank you in advance.
Miguel Duarte
