Warning Message in NX Nastran while using Bolted Connections
Hi
Please look at the below image that alone describes the warning message.
I am solving SOL 101 Linear statics problem of Spare Wheel Bracket with 2.5 g .
I have used Bolted Connections and Contacts for defining the connections.
While doing Model Check up i end up with the below highlighted warning.
How could i rectify the below because of what i guess it is not able to solve the problem?
The fatal warning that i get is also attached.
Suggestions Please.
