bulk modulus in fluid Structure Interaction
Is in Fluid Structure Coupling Analysis , fluid is assumed to be incompressible/Compressible . If compressible  why we give bulk modulus K for analysis?
Re: bulk modulus in fluid Structure Interaction
Siemens Genius Siemens Genius
Siemens Genius
If you are doing acoustic analysis, fluid is compressible and hence bulk modulus is needed. If you are adding mass effects using MFLUID, compressibility is not taken into account.
NX Nastran user's guide has a section on fluid-structure interaction. This guide will give you more details.
Thank you so much for the input
