load distribution options
I'm working with NX 5 Adv. Simulation.
I try to apply a force that changes continuously along one coordinate.
I'm thinking of a linear distribution. Is it possible to achieve this without
dividing the face in several subfaces and make a cascaded force distribution
to approximate the desired continuous distribution?
Thanks in advance!
Florian
EDIT:
Got an answer from Siemens PLM Support, i'll try to translate it to proper english:
The possibility of defining forces as described above is given from version
NX7, but is not possible in NX5.
You can define a 1D-Field that contains a force distribution formula
e.g. (x+875)^2/(1750+875)^2, where x is a coordinate axis.
It is possible to scale the force by defining a force-component.
