memory allocation fails on Win XP / NX Nastran 4.1
N/A
Dear all,
we experience the following phenomenon with NX Nastran: with allocating 1750MB on
a 2GB machine (Win XP) models run fine with 4.0 but not with 4.1. Same machine,
same OS, same config in nast4.rcf.
Log-File in 4.1 produces attached output, any ideas?
Thanks in advance!
NX Nastran V4.1 (Intel Windows XP 5.1 (Build 2600)) Control File:
NASTRAN SYSTEM(303)=1 $ NX Nastran 4.1
Nastran BUFFSIZE=65537 $(c:/femap92/nastran/conf/nast4.rcf)
Nastran SYSTEM(151)=1 $(c:/femap92/nastran/conf/nast4.rcf)
Nastran REAL=533463040 $(program default)
JID='c:/temp/behae000.dat'
OUT='./behae000'
MEM=445644800
MACH='Intel'
OPER='Windows XP'
OSV='5.1 (Build 2600)'
MODEL='Pentium4/1923 (300FEMAP)'
NPROC='1'
CONFIG=15
NPROC=1
symbol=DELDIR='c:/femap92/nastran/nxn4/nast/del' $(program default)
symbol=DEMODIR='c:/femap92/nastran/nxn4/nast/demo' $(program default)
symbol=LM_NO_SNMP=1 $(c:/femap92/nastran/conf/nast4.rcf)
symbol=SSSALTERDIR='c:/femap92/nastran/nxn4/nast/misc/sssalter' $(program default)
symbol=TPLDIR='c:/femap92/nastran/nxn4/nast/tpl' $(program default)
SDIR='c:/scratch/behae000.T120_45'
DBS='c:/scratch/behae000.T120_45'
SCR=yes
NEWDEL='c:/femap92/nastran/nxn4/i386/SSS'
DEL='NXNDEF'
AUTH='27000@LocalHost'
AUTHQUE=0
MSGCAT='c:/femap92/nastran/nxn4/i386/analysis.msg'
MSGDEST='f06'
PROG=FEMAP
NEWS='c:/femap92/nastran/nxn4/nast/news.txt'
NXN_ISHELLPATH=C:\FEMAP92\nastran\nxn4\i386\adina
NXN_JIDPATH=
PATH=c:/femap92/nastran/nxn4/i386;C:\FEMAP92;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programme\Dassault
Systemes\B12\intel_a\code\bin
Current Dir: C:\Temp
Executable: c:/femap92/nastran/nxn4/i386/analysis.exe
NXN_MSG: stderr
FPE: yes
Current resource limits:
Physical memory: 2047 MB
Physical memory available: 2047 MB
Paging file size: 4095 MB
Paging file size available: 4095 MB
Virtual memory: 2047 MB
Virtual memory available: 2033 MB
NX Nastran started Wed Jul 12 16:01:45 WN 2006
16:01:45 Beginning Analysis
All SSE XMM operations have been enabled.
All MMX operations have been enabled.
16:01:45 NX NASTRAN Authorization Information - System Attributes
16:01:45 --------------------------------------------------------
16:01:45 Model: Pentium4/1923 (300FEMAP)
16:01:45 Machine: Intel
16:01:45 OS: Windows XP
16:01:45 Version: 5.1 (Build 2600)
16:01:45 License File(s): 27000@LocalHost
VerifyDriver: Calling WinVerifyTrust
VerifyDriver: WinVerifyTrust returned 0x00000000
Unable to allocate /XNSTRN/ Open Core.
Requested size = 1782579224 bytes (6a400018 hex), errno = 22.
16:01:46 MAINAL: *** OPEN CORE MEMORY ALLOCATION FAILED *** ERROR = 1
16:01:46 MAINAL: *** MEMORY REQUESTED = 445644800 ***
16:01:46 MAINAL: *** PROCESSING TERMINATED ***
16:01:46 Analysis complete 8
FORTRAN STOP OPEN CORE Allocation Failed
Real: 1.375 seconds ( 0:00:01.375)
User: 0.078 seconds ( 0:00:00.078)
Sys: 0.140 seconds ( 0:00:00.140)
NX Nastran finished Wed Jul 12 16:01:46 WN 2006
Re: memory allocation fails on Win XP / NX Nastran 4.1
N/A
Hello Wolfgang,
At 1750 mb, you are very close to exceeding the memory limit for the machine - and
in fact you may have exceeded it. My guess is that you were near the edge for NXN
4 and now with a slightly different executable in NXN 4.1 you are over the edge.
You may want to try requesting less memory. Job may take a little longer if having
to write more to scratch, but it may complete.
Mark
"Wolfgang Schultz" wrote:
>Dear all,
>on
>Thanks in advance!
>OUT='./behae000'
>MEM=445644800
>MACH='Intel'
>OPER='Windows XP'
>NPROC='1'
>CONFIG=15
>NPROC=1
>default)
>SCR=yes
>DEL='NXNDEF'
>AUTHQUE=0
>MSGDEST='f06'
>PROG=FEMAP
>NXN_JIDPATH=
>NXN_MSG: stderr
>FPE: yes
> 1
N/A
Dear Mark,
thank you very much for your response. Of course decreasing the memory value was
our first idea. But the maximum possible request size is only 1000 MB, what is far
away from the supposed limit. Inbetween we found out that the problem does not occur
on all our machines.
BTW: We do not use SP2 for XP because memory limit is much lower (about 1300 MB).
With SP1 maximum of 1750 is possible on several of our machines.
Thaks again,
Wolfgang Schultz
"Mark Donley" wrote:
>Hello Wolfgang,
>- and
>for NXN
>edge.
>having
>Mark
>>Dear all,
>>on
>>Thanks in advance!
>>OUT='./behae000'
>>MEM=445644800
>>MACH='Intel'
>>OPER='Windows XP'
>>NPROC='1'
>>CONFIG=15
>>NPROC=1
>>default)
>>SCR=yes
>>DEL='NXNDEF'
>>AUTHQUE=0
>>MSGDEST='f06'
>>PROG=FEMAP
>>NXN_JIDPATH=
>>NXN_MSG: stderr
>>FPE: yes
>> 1
N/A
I had a similar issue and found that if you leave the memory slot blank, the machine
will interpret how much memory it needs. I set the memory at a very low number
and it ran fine so from then on I just leave it blank. In the settings file it
should have something along the lines of an "auto" setting for that.
Rob
>Dear Mark,
>was
>is far
>not occur
>MB).
>Thaks again,
>Wolfgang Schultz
>>Hello Wolfgang,
>>- and
>>for NXN
>>edge.
>if
>>having
>>Mark
>>>Dear all,
>1750MB
>>>on
>>>Thanks in advance!
>>>OUT='./behae000'
>>>MEM=445644800
>>>MACH='Intel'
>>>OPER='Windows XP'
>>>NPROC='1'
>>>CONFIG=15
>>>NPROC=1
>>>default)
>>>SCR=yes
>>>DEL='NXNDEF'
>>>AUTHQUE=0
>>>MSGDEST='f06'
>>>PROG=FEMAP
>>>NXN_JIDPATH=
>>>NXN_MSG: stderr
>>>FPE: yes
>>> 1
N/A
We are running SP2. I leave the memory allocation blank for the analysis. Regardless
of the amount of memory in the PC, I believe that there is a 2Gb memory limit per
task in XP
>Dear all,
>on
>Thanks in advance!
>OUT='./behae000'
>MEM=445644800
>MACH='Intel'
>OPER='Windows XP'
>NPROC='1'
>CONFIG=15
>NPROC=1
>default)
>SCR=yes
>DEL='NXNDEF'
>AUTHQUE=0
>MSGDEST='f06'
>PROG=FEMAP
>NXN_JIDPATH=
>NXN_MSG: stderr
>FPE: yes
> 1
