need Help to set mesh control
N/A
1. is there any UFunc API to set mesh control?
2. if i want to use NXOpen API,
(std::vector<:meshcontrol> densities1;
densities1 = meshControlBuilder1->CommitDensities()Smiley Wink
How to collect the CAE face and CAE edges using C++ NXOpen API?
3. i am collecting required face thorugh UFunc and trying to set the mesh control for all the face edges. it is giving me an error as below.
CAD face is degenerate (2A/P < tol)
UG face (proto) 44197, PS face node id 815
at location -3.851546, 1.356175, 40.046000
UG face (proto) 45581, PS face node id 4003
at location -3.821365, 1.225035, 40.033912
UG face (proto) 45759, PS face node id 18556
at location -3.472448, 1.516663, 42.035659
UG face (proto) 45673, PS face node id 18554
at location -3.472352, 1.476390, 42.036151
UG face (proto) 44203, PS face node id 767
at location 3.636978, 1.486977, 42.876561
*** NOTE:: in line 7832 of F:\workdir\reference\NX602_8\src\caetopo\app\ind\caeabscreate.c at Fri Sep 30 12:07:19 2011 India Standard Time
+++ Some CAD issues are reported in the syslog.
Missing resource block.
Validation failed but CPP author license exists - d:\BACKUP_QZ-301\GE-Restricted\eBucket\application\eBucketBat.exe loaded
Successfully loaded dynamic module D:\Apps\UGS\NX6\ugii\libnxopencpp.dll
can you help me to resolve this issue/
