problem with java runtime
Hello
When I want to make a report of my simulation I always have the same error. I can't find the solution.
Can someone show me a step by step guide how to fix this. I have the latest 64bit java version.
Betreff: problem with java runtime
TomVC,
sorry, but I think the snapshot is too small. I can't read the text in the message window and the magnifier doesn't bring any improvement. Could you edit your thread by posting it in a larger format.
This is only a hint, because I'm not a specialist for java runtime errors.
May be it helps. Good luck, Michael
Siemens Legend Siemens Legend
Siemens Legend
Hi TomVC,
please set the environment variable "UGII_JAVA_HOME" to your Java installation.
You can set this as an environment variable or set it in the ugii_env.dat file in the %UGII_ROOT_DIR%.
Boris
Like this?
