2d mesh and 3d mesh
hello,
i designed a plate of thickness 5 mm and length and width are 150 and 50 mm respectively. when i compare the analysis between  2d and 3d mesh the results are different. but actually result should be same..
please help me
Re: 2d mesh and 3d mesh
Does the plate undergo bending? If so, how many solid elements are used through the thickness of the plate, and are they linear or parabolic? 1 solid element through the thickness of the plate isn't sufficient. 3 is better.
Mark
