cancel
Always show error: Datach module terminated abnormally.
Hello eveyone,
I'm really need help right now...
After i installed Simcenter11 ,every time i run the ESC simulation,the result always stop at DATACH-Module check. And it says encountered a problem and terminated abnormally. But if i change back to NX10 , it will be ok and i can get the result. So i am wondering  if there any setting details that i don't  take a look?
My Simcenter Ver. is 11.0.1.11 and LMTOOLS Ver. is 11.13.1.3
Re: Always show error: Datach module terminated abnormally.
Roger,
Can you send the LOG file from a failing solution? When in doubt, GTAC is a good option too.
https://www.plm.automation.siemens.com/en_us/support/gtac/
Mark
