Application advice
I am trying to identify the best simulation product for a wet multi-disc clutch, looking for oil flow at various speeds/rotations per minute, generated heat and friction forces if that will even be possible. Any suggestion will be appreciated. For models we have Pro-E and Inventor-Autodesk, but we could get Siemens if we need to.
Thank you much
Daniel
Re: Application advice
Daniel,
The MAYA NX Flow development team is looking very closely at your problem. We will coordinate with you outside the forum and, with your permission, post a follow-up on the forum once we have determined the best approach for this problem.
John
John Tiernan | Regional Manager
MAYA Simulation Technologies Ltd
M +1.734.395.6854 F +1.312.803.2118
john.tiernan@mayahtt.com | www.mayahtt.com | datacenter.mayahtt.com
