cancel
Boundary Layer in combination with 2D Dependent Desh / Periodic Boundary Condition NX 11
Hey there,
I am trying to use the bounday layer function in combination with a periodic boundary condition. Background is to simulate a slide of the flow domain as shown in the screenshot attached.
I know that the mesh on each cut surface need to be equal to eachother.
Every time I use the 2D dependet mesh to make sure both surfaces have the same mesh structure the boundary layer structure got lost.
I am using NX 11.
Do you have some tips and tricks?
Thank you
Re: Boundary Layer in combination with 2D Dependent Desh / Periodic Boundary Condition NX 11
Hi Tobias,
Just split the model and use extruded mesh for your boundary layers. Combining boundary layers function with other funcitons is not always working
