Calculate rpm of the turbine in flow simulation
I would like to run a flow simulation on a turbine blade inside a valve and calculate the rpm of the turbine blade based on the inlet and outlet pressure as the boundary condition in the valve in NX Flow Simulation. Considering the turbine blade is in free rotation and the flow medium would be water.
Thank you for your support.
Jerry
