Changing the font size and type of the color bar
Hi all,
I solved Acoustic response analysis and observed the sound pressure level distribution. So when I took the snapshot of the image for the report the fonts of the color bar is not looking properly. So I want to increase the font size and the type so that it will be visible clearly in the report.
Re: Changing the font size and type of the color bar
To change the font size go to "Edit Post View" ---Text Tab, then change the font scale with the slider bar
The font can be changed in the preferences for "Visualization"
Dear Elljay,
Thanks for your reply but I couldn't get the option which you mentioned.
I tried the following steps
Tools--options--Display--Visualization
Siemens Legend Siemens Legend
Siemens Legend
you need to modify the Postview settings in Postprocessing.
Find a description how to find the "Edit Post View" Menu in the Documentation:
https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help#uid:xid1128419:index_advanced:xid433696:x...
You will find the "Legend" Tab to modify the legend settings for the colorbar and the "Legend Text" Tab to modify the textsize and the numbering format.
Best regards
Boris
