Colour 3D Printing of CAE results
Has anyone had success with colour (contour plot), deformed shape 3D printing of CAE results from NX? The difficulty here is to get the results exported in some format understood by the 3D printer, ideally a VRML file. It is possible to export a JT file of results, import the JT in the Modelling application and then export VRML but unfortunately then the colour is lost.
Re: Colour 3D Printing of CAE results
Siemens Legend Siemens Legend
Siemens Legend
Hi Lionel,
did you try to export the colored JT from Viz Mockup?
A material diffuse color tag is exported. I am not sure if your 3D Printer can read this correctly.
Boris
