Combining loadcases only of the groups
Hi everybody,
I know that there is the command Results Manipulation in NX post-processing to combine different loadcases however you want. But as it takes kind of a long time to combine the whole model I wanted to ask if anybody knows a possibility of how to combine loadcases only for a group as there would be less elements/nodes then. This way the process would maybe be faster. Is there a way or is there no possibility to do so?
Thanks for sharing your thoughts!
