Creating permanent coneheads
N/A
I used OpenNX(using APIs) to write my own minimum radius functionality. What I wanted
is to save the result by creating permanent coneheads. I found an API "UF_DISP_labeled_conehead"
to display temporary coneheads. Can you suggest me a way to create permanent coneheads.
Similarly I want to display result for slope analysis for slope less then specified
degrees. Can you suggest me the way to do this.
I could not found any sample code in uganswer.ugs.com for slope analysis to do this.
Note: Please mail a copy of reply to sachin.goyal@geometricsoftware.com
Sachin Goyal
Geometric Software Solutions Ltd.,
Mumbai -79
